fuel
c0mrade
Hi gent's , quick question ?
i have a m135i (stock ) on my fuel tank cap it said 10% eth.
my car has a 52L , so i can mix 5L to a full tank .
if i drive the car to half tank and put a bottle of NF ultra in it
will this cause any damage ? i would like to see if my car pulls any better .
:thumbs:
Psypher13
NF in the long run will always have some negative effect of your car
eth - should be fine as you will be running minimal ratio
Woodies
I put NF (silver 1lt) in about 40-50 litres and it makes a big difference. Takes about 30kms for the ECU to adapt and then you sure notice it.
Only used it a few times, so dont know of long term damages. So far so good.
Fuzz@tinyNET
Use the NF as stated on the bottle - a full bottle is too much to half a tank...
That being said, if mixed out of spec, expect your spark plugs to be fouled, along with accelerated carbon depositing in the cylinders.
You're better off using a 'clean' mix like OB1 or Witch's Brew, as you'll achieve the same results.
Sent from my iPhone 6+ using Tapatalk
c0mrade
sorry bud what is witch"s brew ?
c0mrade
sorry guy's , i think the question has been miss understood .
i run 10% eth to a full tank every time , IF i run my tank down to half,
and i add a bottle of NF ultre (silver ) to it will there be a problem ?
:ty:
Fuzz@tinyNET
:ty:
Use the NF as stated on the bottle - a full bottle is too much to half a tank...:bin:
Kish2604
Administrator
for maximum octane boost mix 1 bottle of NF ultra to 20litres of pump fuel as stated on the can. the presence of 10% volume of ethanol in the fuel already in the tank is marginal and will not negatively affect your fuel mix.
on race days i personally use a concoction muuuuch stronger than stated above.
ps. please update your signature with your car details so it will be easier to offer advice.
c0mrade
Hi bud i have a stock M135i . thank's for the info but will i feel a difference ?
:thumbs:
Kish2604
Administrator
Most definately!...
From my experience with the M135 motors the ones with the EWG control systems dont particularly like ethanol so the best solution currently is the use of race gas if available or octane boosters to supplemement the pump fuel...
