Foam Blaster Foamer Trigger Sprayer produces a large volume of foam for demanding cleaning jobs. Use the Foam Blaster Foamer with foaming carpet cleaners, all purpose cleaners, Wheel and Mag Cleaners and degreasers. It makes big cleaning jobs easier by coating surfaces with clinging foam faster.
For some jobs, foam is better! Foaming products are designed to cling to surfaces better or to leave the surface less wet, as is often the case with carpet cleaners. Get the maximum benefit of foaming products with the Foam Blaster Foamer Trigger Sprayer. It has the highest output in the industry so you can coat surfaces quickly.
Foam Blaster Foamer Trigger Sprayer is a must for wheel cleaners and All Purpose Cleaners where you want the product to cling onto the surface and work. No detailing kit is complete without a few of these!
- Unique foamer tip produces large volume of clinging foam
- Large heavy duty design holds up to the most demanding usage applications
- "Comfort-Grip" cushioned trigger minimizes user fatigue
- Highest output - ideal for large, heavy duty foaming requirements
We listed this about a month back and I only got to play around with it the past weekend. Very impressed with the foaming action from my normal APC. Thick clingy foam helps esp when scrubbing my tyres etc. :thumbs:
Click to view on the CD site
