BMW M said:Dont shock yourself!! These control units carry huge loads in capasitors. 25000V if memory serves right... BE CAREFUL when checking wires and control units.
E36cab said:Hey guys, I think i found the problem
Last night after driving for about 20min the lights started flicking again mostly after taking off at an intersection.
When i stopped the car and checked the headlights the left one was not working. If i turn the lights off and then on again it comes back on.(note, don't turn off engine and lights)
I think it might be the bulb, any suggestions?
msm said:Check if both bulbs are flickering or one only. If one side only, then swap the bulbs around (i.e. left to right).
If the problem follows the bulb, then it's the bulb. If the problem remains on the same side, then it's the control unit (or wiring).
Legacy said:D2s bulbs right? If yes I have plenty.
E36cab said:Thx Onyx, called them R1100 each and R95 for delivery.
Now i just need to swop the bulbs from left to right to figure out if it really is the bulb.
