Flat tyre warning failure... Calling e92 M3 owners..
Jerez
... Or anyone else in the know.
Switch car on and engine management light stays on.
I drive monitor show tyre pressure failure.
Cars then restricted to 4k rpm.
However, when switched off and back on, then te problems gone.
Other forums say:
Throttle actuators
Moisture
Rear wheel bearing.
Can anyone aged some light on this?
Jerez
Demon tweaked said:
I get rear brake light failure as an error, happened 2 or 3 times since April. just adding to your list.
Get that too- I believe that there are 5 small bulbs which make up the 2 brake light sections on each side.
£5 a bulb--- R75 each
