Ian was just being polite as he didn't want people flooding me with requests. (Not that I mind, always willing to help
And Ian It's a pleasure as always, I'm pleased I managed to solve the fuel problem for you, with todays prices it must have been harsh trying to feed that puppy at 25L/100Km!
Over time hopefully we can replace those sensors with new ones, but for now, nothing like making a plan.
It's interesting the misleading comments given to Ian when he was trying to diagnose this car. On todays hi tech engines it's all to easy to just start replacing stuff when it's not always needed. Ian was told many times he HAD to replace the CPS and O2 and electronic thermostat sensors to sort it out. Well no he didn't need to, for now at least.
1) The Camshaft position sensor on a NON VANOS engine (CPS) does nothing more than tell the ECU what cylinder to fire during startup. If it's not working the fuel injection runs batch fire instead of CIFI (Cylinder Individual Fuel Injection) and ONLY during starting. Once the engine is running it's not needed, only used for quicker starting of the 8 cylinder engine.
2) The O2 sensors were really stuffed causing a rediculously rich fuel mixture to the #1 cylinder bank. All I did was unplug the damn things, allowing the ECU to substitute the stochiometrically correct default value of 0.45 V and allow the ECU to calculate an almost perfectly corect mixture from the AFM and temparature reading instead. His cats have been removed so it makes little difference. O2 sensors are primarily there to protect and lengthen the life of the cats. The older M60 engine with no cats came with the O2 sensors missing from the factory and worked fine running on default ECU substituted readings.
3) The engine electronic thermostat. This is a perfectly normal functioning thermostat with an additional heating element that allows +10 Degrees C increase whilst cruising on the highway. This improves fuel economy, but in reality it's only a few percent if even that, and at like 2 grand new cost he can safely drive the car for now as long as the "normal" part of the thermostat is functioning correctly, and for now it is.
