F8x M2-M3-M4 KW HAS KIT (Height Adjustable Springs)
FiRi@Rennzport
KW’s sleeve kit for the F87 M2 and F80 M3 / F82 M4 allows a large range of height adjustment while retaining the factory electronic damping control. The factory spring perches are removed from the front dampers, and KW’s own threaded height-adjustable perches are installed. The kit includes progressive rate lowering springs for each corner of the car, height adjustable spring perches for the front and rear, strengthened and shortened bump stops and KW shock sleeves to protect the OE BMW dampers. The KW H.A.S. kit is EDC compatible!
Lowering Range:
Front Lowering: 0.4″ to 1.2″
Rear Lowering: 0.2″ to 1.0″
Fits :
- F87 M2 and M2C
- KW’s sleeve kit for the F87 M2 and F80 M3 / F82 M4 allows a large range of height adjustment while retaining the factory electronic damping control. The factory spring perches are removed from the front dampers, and KW’s own threaded height-adjustable perches are installed. The kit includes progressive rate lowering springs for each corner of the car, height adjustable spring perches for the front and rear, strengthened and shortened bump stops and KW shock sleeves to protect the OE BMW dampers. The KW H.A.S. kit is EDC compatible!
Lowering Range:
Fits :
- F87 M2 & M2C
- F80 M3
- F82 M4
Price : R20,900
••• RENNZPORT •••
Firi 065-950-6027
Zee 083-401-2299
Nationwide Courier Available
