F30 Sat Nat retrofit
Jerez
So, we've had the f30 for some weeks now and it needs a Sat Nav.
There are some 80 gb hard drives for sale on eBay for £500 OEM but I wanted to know if anyone has done a retrofit install on an f30.
I have the I drive
I have the screen
I have the front loader
Just to give you an idea of existing equipment
Hugo_za
It is pretty straight forward to do the retrofit. Coding is the hardest part, but if you go the ebay route just pay a little extra and they will code and activate everything for you which should make it plug and play.
Bear in mind that you will have to have the maps installed by BMW which is going to set you back another couple of K.
