mikovhe said:
Nastaliq said:
When parking, do not expect your gear to hold the car.
this is why, you place foot on break pedal, pull up handbrake lever, then put car in park, then take foot off break pedal
I have heard that I will take that as the gospel and train my co-drive ie Wife :roflol:
yep, this protects your gearbox, so that when you pull out of park, you don't hear/feel/grit that grinding sound/feel. Its a smooth click into drive.
Also, just ensure that the co-driver brings the car to a FULL HALT before changing from reverse into drive for example or vice versa.
Its not the same as a manual, where you push in the clutch while the car is still rolling back, and then into 1st.
Full halt on brake pedal, press button into desired gear.
over time, and trust me, this will protect the gearbox, and prevent your car lurching forward when pulling up the hand brake.
