KrS24
Electromagnetic not Electric ///M
Imagine if this made its way into a road going vehicle.
Taken from: EM Drive
The EM Drive is at it again, it seems. Recently, Mike McCulloch, from Plymouth University in the UK, unveiled a hypothesis that aims to explain how this physics-breaking mode of travel could actually work. And his idea has some proponents of this method of transport rather excited.
But before we go into the newly proposed theory: a quick summary of what the EM Drive actually is.
In short, the EM Drive could allow us to explore our universe in ways that, today, we can only dream about … if it’s ever developed, that is.
It works (or should work) thanks to microwaves. The claim is, you bounce microwaves back and forth inside a truncated cone, and the result will be a thrust toward the narrow end of the cone.
That seems simple enough, yes? After all, you are just converting kinetic energy into another form of energy.
Well, here is the kicker: The total momentum increases as the device begins to move. That is like placing yourself inside a box, pushing on the side, and generating thrust. Sounds silly, doesn’t it? Well, here is another kicker: To date, a number of teams around the world have built their own versions of the EM Drive. And they generate thrust… but only a tiny amount.
And, alas, we don’t know where this increased momentum comes from. Critics assert that this is a violation of the law of conservation of momentum (which is part of the fundamental physics that governs our universe). Moreover, scientists assert that there are other effects that could, in essence, be producing a false positive and generating this increased thrust.
To that end, a host of scientists have been trying to work out whether this is an anomaly or if it actually works (and if so, how). This is where McCulloch comes in.
A new idea
In short, the new hypothesis is based on ideas regarding inertia and the way objects move under very small accelerations. It has to do with something called 'the Unruh effect'. This asserts that an accelerating object experiences black body radiation, meaning that the universe warms up when you accelerate. And in this regard, according to McCulloch, inertia is the pressure the Unruh radiation exerts on an accelerating body.
As MIT notes, "at very small accelerations, the wavelengths of Unruh radiation become so large they can no longer fit in the observable universe. When this happens, inertia can take only certain whole-wavelength values and so jumps from one value to the next. In other words, inertia must quantised at small accelerations."
Thus, the inertia of photons that are inside of the aforementioned truncated cone have to change as they bounce back and forth. And to conserve momentum, this must generate a thrust.
In an email interview, RIT astrophysicist Brian Koberlein summarises:
The Unruh effect (basically) says that an accelerated object should see a thermal background due to background quantum fluctuations. The calculation of the Unruh effect is straightforward, and isn’t controversial. Unruh radiation is (basically) the idea that in the detection of this thermal background you can trigger the emission of real particles. In other words, can you create real radiation ‘out of the vacuum.’ So they are claiming Unruh radiation is real, and causing the EM effect.
So. Is this the solution we needed? Well, maybe not.
In the end, there are a number of ways that individuals have attempted to explain the EM Drive, and to date, none of them have been shown to provide a conclusive answer. And while MuCulloch’s idea is based upon long established theoretical ideas, he applies the ideas in rather unconventional (and controversial) ways.
Koberlein notes that the work, in itself, is certainly valuable, stating, "they are trying to fit the results to a model, and looking for testable predictions, both of which are great". However, he clarifies, saying that we need to maintain a healthy dose of skepticism.
In relation to the idea that the Unruh effect is responsible for inertia, he asserts, "the quantised inertia idea at least makes some predictions that can be tested, so that’s not bad;" however, this does not mean that it is responsible for the thrust that is seen in relation to the EM Drive.
He continues, "the idea that the EM effect can account for the flyby anomaly is weak tea. To begin with, just because it can be made to fit under certain assumptions, it isn’t the same as predicting an effect. Secondly, there are lots of proposed explanations for the flyby effect, most of which are more mundane and don’t require exotic physics (such as radio chirps)".
So it seems that it may be a little early to assert that we have figured out how the EM Drive really works. As Koberlein concludes, "The biggest challenge they still have is that these results are so extraordinarily small that lots of things can explain them. They aren’t there yet, though".
A new idea
