EGT Gauge...
Garreth
Hi guys, I am saving up for the down pipe to remove the dpf. I am also looking at taking a few precautions like a EGT to monitor things. While they at it they can add a nut in so that the probe on the down pipe can be screwed in.
Anyone that has a good quality EGT? That you can recomend. Would like to get a fitting that takes up an air vent with the gauge built in(same as a boost gauge the vw gti's use). The 4X4'S I do trails with use a mad man monitor this helps with waring you in time before you damage the motor. I am not so keen to run this as it's a lot of cutting and fitting sensors.
Kish2604
Administrator
a mad man set up is pretty much the only reliable set up i know off...
keep us posted if you find another alternative...
