DieselFan
Hi guys,
I drove my 330d for the first time in 10 days last night and was having a few problems with my lights. The warning light on the dash would come on for either the front or rear lights. It wasn't a long drive but I felt something wasn't right. So today I took it for a drive and hit a hill in 3rd gear at 2000rpm. I was in drive and put my foot flat and nothing happened it just slowly crept forward. It literally felt like I was driving a real tractor. It was also smoking quite badly.
So I took the car to my mechanic and it turned out to be a boost leak at the EGR seal. And a earthing fault with the lights. So the car is booked in for tomorrow.
I asked him about the EGR delete and he said he hasn't seen any decent kits around so at the moment until he finds one he wouldn't do it. They are the same people that did the swirl flap delete. And have recently done the engine mountings on the car. We also checked the main crank shaft pulley dampener and that was fine as well.
So what are your guys views on the EGR delete? I have looked at the forum and people suggest the Land Rover Blanking Plate. But it doesn't look very high quality?
What do you guys think of this one Allard Aluminium EGR Delete Kit?
How much of a rough idle can one expect from a 3litre diesel? Its to the point where if I have keys in the side of the door they will vibrate together making a noise. Its quite bad when the car is stopped and in drive and is a bit less in neutral and almost completely goes away when i rev the engine slightly in neutral. And there is no vibration when driving. And what else could be the cause. I have just had engine mounts replaced. The front pulley looks fine.
