E9x n55 launch control
SlimmJimm
Hi guys,
I tried following the book to use the launch control to the tee but the flag doesn't appear and my revs stay below 1200rpm.
I have a e92 335i n55 with the dct transmission.
Anybody successful in this care to share the secret?
Sent from my E6653 using Tapatalk
922-ZN
SlimmJimm said:
Hi guys,
I know most people under estimate how hard you need to press the brake, press it HARD, also make sure car is warmed up to normal temps
Psypher13
Make sure oil is warm
Drive car for about 20km before trying to launch
Steps
1. Make sure car is stationary
2. Make sure dct is on and sports mode off
3. Press brake and keep pressed
4. Hand brake down
5. Put car into M1 (gear)
6. Press sport mode so it's on (highlighted by green)
7. Press dct ONLY once (dct sign will show on dash)
8. Once all engaged press accelerator right to floor past the Kick down
You will the see flag on dash and revs increases for launch
Hope this will help
Otherwise go check out my YouTube vid
:coolShake:
SlimmJimm
Thanks man, i got it right, i was at Tarlton this evening...... Did a 14.7 on a stock car with pump fuel...... any tips to better the time???
Car span alot and round 2 i tried easing of the throttle but messed it up and ended with a 14.9
Also anybody got a contact for helmets lol
Psypher13
Not bad
What mods have you got ?
Using octane or race fuels will help
Good semi slicks for traction
And practice - it takes time to get the feel of ur car
Spinning ain't winning. You definitely need some better tyres if you're spinning that much at stock power level.
The key to a good 1/4 mile time is a quick 60ft. Some good tyres on there and you'll do better for sure.
Sent from my HUAWEI GRA-L09 using Tapatalk
SlimmJimm
[quote='"]
[/quote]Thanks man, if u look at my other post the clutches were replaced too, so hoping that will atleast help the next time i go, tyres are something i will have to budget for haha im pulling off nice and slow these days lol.
I also wanna try some race fuel..... What have you guys used and what is your opinion on the different brands available?
