Putrid4444
Hi guys,
I have a question for the e9x m3 guys regarding ticking noise coming from Under the plenum in the "V"
Some background info:
Car is a 2010 E92 m3 6spd
Bearings were replaced 10 months ago by previous owner
Actuators were replaced
Water pump was replaced
All as preventative maintenance
I bought the car maybe just over a month ago.
Car went through quality check by BMW before i bought it, BMW said everything is 100s except it needed a oil service and new oil pressure switch, that was done.
Got the car back, the oil readings were irregular ie: Car would read oil is full, then after 20-30km it would read half, then almost empty, Once you reset the oil level, it would be back to full and so on.
The other issue is, when the car is completely warm, there is a irregular ticking sound that comes from under the plenum in the "V"
When you hold revs at 1200rpm the ticking sound is more present than at idle.
I should also mention that it does not do this on cold start, only when it gets to proper temp 90-100.
The ticking sound is also not audible/there when revving over 1800rpm.
I have got multiple dealers and sources to diagnose the issue and have done quite a lot of research online regarding the exact same issues others are experiencing.
The dealer which knows the car (It has only ever gone to this dealer) first diagnosed it as possible actuator gears getting stuck, but after further diagnoses pinned it down to be the timing chain tensioners which need to be replaced.
So today i just got the car back from such repairs (Oil leveling sensor for the oil reading issues and the timing chain tensioners for the ticking sound), the car is doing the exact same things as previously, so im pulling my hair out here.
Dealer says i need to top it off with a litre of oil and drive it over the weekend and if the problem persists I should bring it back for further diagnoses.
From what i have read up on other forums, most of the issues they had from the ticking sound was the heat shield by the manifold, yet even after replacements and adjustments the sound was still there.
All of the issues with the ticking sound was always after a oil service/change.
Some blame it on the type of oil used, but i dont see how it could be that.
PS: This is NOT Mr Rod making knock knock jokes.
The video below is the exact noise mine is making:
Has anyone else experienced this problem, and if so what was their fix?
