E90 water pump
chase-GP
Hi Guys,
My brother has been having problems with his E90 323i,
Besides the battery registration problem...
One of the problems is the water pump.....
he had his car on a diagnostics machine to find out what's wrong.
they said that his water pump keeps running it does not switch off when the car does.... its constantly running and this is the cause of his battery running flat!!
has anyone had this problem before with the water pump running non stop????
or is there something else that needs to be altered to correct the pump switching on/off
where can he get a cheap water pump?
Zubz335
I had mine replaced a week back, orange temp light came on then red temp light, water pumps on e90 are a sickness, better to replace them if they faulty in anyway
Sent From My Samsung S5 Lte
sclass
Electric waterpump is around 6-7 grand, I'm not aware of any aftermarket alternatives, but I think the pump and thermostat are best bought from dealer....these aren't items you want to cheap out on.
chase-GP
Yeah I think BMW wants like R7000 just for the pump...
and its crazy expensive just for a water pump!!!
Caddy101
Had my water pump and thermostat replaced by Tunetech a while ago.
Total cost, including labour R10 600
Philip Foglar
Lizzard said:
Maybe this will help :rollsmile:
http://www.g-drive.co.za/shop.html?page=shop.browse&category_id=6943
My waterpump packed up about 3 weeks ago, also electric, 2005 E90 330i and bmw quoted me R7300 something for it. I phoned goldwagen and they gave it to me for R4500. Maybe try goldwagen and see what they charge you.
Hope this helps
Just curious, since yours is also a 2005 model, have you checked your car's coolant temperatures through the hidden menu (menu 19 unlocked, then menu 7...)? Quite interested to know what sort of temperatures you see and how it changes based on driving conditions etc.
Lizzard
Hope this helps
When my steering angle sensor started or the triangle and brake light I bought bmw diagnostic cable and software to resolve that, so to answer your question no I don't use the hidden menu but do use INPA, DIS and ISTA to check the car.
But the temperature fluctuates between 85 and 110°C
mubz
At around what mileage can one expect water pump to fail on the e90's
Philip Foglar
It varies of course, but most seem to say anything around every 100k km, and same goes for the thermostat.
Hope this helps
Thanks. I am baffled with mine. The temperatures seem to go between 74 and 98 degrees, but typically stays around 80-84. I just recently replaced the thermostat and even had the ECU checked and software updated. Temperature sensors were replaced ages ago when it was suspected that it was causing these over-cooled temps. It is also interesting to note that the OEM and replacement thermostats are rated at 97 degrees, but I gather that the ECU then regulates the coolant temperature based on what the engine load is and there how it is being driven. Most places including the BMW dealers insist that my temperatures are wrong, but the ECU specialist that BMW in fact uses for their tricky repairs says that there is nothing wrong. So very odd.
If you don't mind, it would be interesting to see if the temperatures that you saw on via INPA is the same as the hidden menu. It should be, but would be nice to confirm this. To access this, press and hold the odometer reset button for roughly 10 seconds to bring up the hidden menu, then repeatedly press the same button until you get to menu 19, add up the last five numbers of your VIN number and enter that in, then once the unlock message is displayed cycle back to menu 7. This is show the coolant temperature which in theory is the same as what INPA would have shown, but curious to know if that is the case. I would appreciate this if you can check this out whenever you have time.
Lenny Dhaver
chase-GP said:
Hi Guys,
chase-GP said:
Hi Guys,
i had pump replaced for R5225.00 , go figure
had my e90 water pump replaced for R5225.00 + labour. SSM in Edenvale
WimpieJoone said:
I Have exactly the same problem now,please advise?]
Try Slip Stream Motors...had mine done there.
