Hi all, hoping for some guidance here.
I have an E90 323i that is in the habit of dying/cutting-out. Simple as: clutch-in, gas-off and revs drop to zero. No warning lights, no problem restarting and no particular pattern (perhaps only happening after the engine has warmed up).
I was given a quote of around R30,000, which included replacement of both VANOS solenoid valves, exhaust camshaft, both impulse sending wheels and so-on.
When I queried the quote I was given three different diagnoses - none of which made sense. I opted out of the repair and initially the problem went away. It has however returned so there is obviously something going on that needs attention.
Any suggestions as to a likely diagnosis or a good (trustworthy) diagnostic/service centre (Sandton / Randburg / Roodepoort) would be appreciated.
Regards
Keith
Regards
Keith
