E90 LCI sunroof -HELP
Demontec
Howsit gents
Was wondering if someone could advise on a quick fix or reset for my sunroof before I go through the hassel of booking my car in at Bmw
Yesterday I had the sunroof opened and upon closing it it did close completely but then dropped in the opening position again
Basically it went back to the position it was in before completely closing similar to when it slides all the way foward to the last point were it moves back up into place (level of the roofline)
Any advise would be appreciated Thanks:rollsmile:
GGM
had a similar issue , mine was below the roof line and had a terrible wind noise coming through.
bmw reset it at the last service but heres what i found on another forum :
ALL you need to do is initialize your sunroof.
What you do is you get into your car, put your fob in the slot and turn the car ON (ie don't start it - but push the start button with your foot OFF the break/clutch)
Now, push and HOLD the sunroof button up (vent position). After about 15-20 seconds, the sunroof will vent. CONTINUE HOLDING THE BUTTON UP. After anouther couple of seconds, 15 or so (could feel long, but keep holding) , the sunroof will close, the open completely, then close completely.
Once the sunroof has closed completely, the proccess is over. It's important that you do not let go of that button while the proccess is happening.
Warnings might come up on i-drive or the on-board-computer. That is normal during this initialization.
good luck ! :thumbs:
levi325is
Hey,
Try this, I know it worked for me.
Put your key in the slot but dont start the car and then press and hold your sunroof button in the sunroof tilt position.
In about 20 secs the sunroof will then start to open completely and will then close again.
You must ensure that you hold the sunroof button in the tilt position through out the whole process until it is in the closed position.
I hope this helps :thumbs:
Demontec
Thanks a Mil. GGM3 / levi325is
Will give it a shot this evening once I get home and keep you posted
:thumbs:
Demontec
bmsportzn135i said:
Please do let us know.
It cost me R1800 for bmw to sort mine out.:thumbdo:
Will do bud...Luckily still have MP if I dont come right with the reset mentioned above.
Demontec
Howsit
Sorted out in 10 seconds
As the guys above have stated, Works quick and easy
Thanks so much gents:thumbs:
