E90 Front suspension update
Sheldon13
Hi all
What would be needed to do a front suspension update on a 320i E90 LCI and would what be an estimate cost on it.
not sure what you mean by update... I can offer you very High quality parts PM me so we can discuss you needs :)
Sheldon13
Sorry if i was vague in my first post.
What i meant was replacing the parts that could be worn out.
My car has runflats on and the ride is terrible.
There is a hard noise when hitting bumps and a slight rattle.
The handling is also not that great which i think the control arm bushes need replacing.
What else would there be a need to replace
ClassicB
Your car is still fairly new (lci), so doubt you would need major suspension work. Have it checked before replacing unnecessarily.
Run flats are hard and crap on the road and that is probably your biggest problem. Change those and your car will feel loads better!
DieselFan
Have your car inspected before going replacing expensive suspension components
Ralf*
agreed
your car is not old enough to have developed serious suspension wear-and-tear, unless it was utilized on undulating dirt roads a lot.
Run Flats have an undesirable side effect of a very hard ride quality, due to the rigidity of the side walls.
If you are in the East Rand, bring it my shop to allow my suspension technicians to pull and push all over the suspension components to see if anything is worn out...inspection is FREE.
Sheldon13
Thanks guys for the advice.
Thanks for the offer Ralf and i think i am going to take you up on that offer.
Car has never been on a dirt road.
Will drop by soon and will pop you a pm when i am coming through.
:thumbs::thumbs:
