E90 Front HeadLight
alexzplee
Is it normal front headlight only outer side of the internal light to be lighted? Tq.
Picard
Hiltonmarx said:
Yes and on brights all lights on
I'm sure my one is like that too. The inside ones just have the angel eyes? Only the outer ones are for normal lights and brights?
samman325
For normal halogen headlights, the outer are normal lights and inners are brights.
On xenon, outer is still normal but when you switch brights, inner lights up and outer gets brighter too.
Sent from my SM-G925F using Tapatalk
PizzaBoy
Mine also doesnt work. Only outer works as dim and brights? Is this normal? I saw somwhere that the inner ones is just dummys
Sent from my SM-N910F using Tapatalk
DieselFan
The 1 series has dummy high beams. On the e90 the outer lights are low beams and the inners high beams. And if you have xenons the low beams are bixenons which opens a shutter when you turn brights on.
moesaley
on LCI's the inners are dummy's. they have a black lens
the outers are bi-xenon, meaning they do hi and low beam
