E90 330I ecu replacement
MegaM
Good day fellow fanatics,
Can anyone recommend a auto electrician in the west rand area. I have a water damaged ecu that needs replacement. I have contacted a few companies regarding this, yet i am not sure about credibility as well as price indication seems way to high.
Any advise regarding this would also be greatly appreciated. Is it possible to seal the ecu compartment to prevent future water penetration?
MegaM
Thanks, Gert (obd worx) sorted me out for now, next question is, is their a solution or modification that one could do to prevent water from getting into the ecu compartment, perhaps sealing off the water drain plug and drilling a few holes on the lower part of the ecu compartment?
tdi_stig
I have heard guys drilling holes. But if you keep your drains clear of leaves and debris it should never reach the ecu compartment
