E90 330d Rear Diff humming noise
330Tractor
Recently my rear diff has started humming, and it is getting worse by the day.
Is this a common problem on the E90 330d's? Does one have to replace it, or is there places that can recon it?
Weskus330d
Hi
Got same problem, had my oil drained, but that didn't help at all. hopefully someone has a fix.
Solo Man
Could be tyres related. Had this noise on my 330i E46 and put my E46 330d wheels on the rear and noise was gone. Swopped the old back wheels left to right and noise was 98% gone. Just my 2c
Bmwed
If you can play the noise with your petrol pedal then its your diff. My car is currently in for a diff replacement. Get it sorted as soon as possible you might be lucky and its just the bearings. I drove mine with that noise for over a year and i did damage to the "big" gear on the inside (whatever it is called). if you are in Jhb i can give you a number for a guy that only replaces the bearing at a very reasonable rate. My car is getting a new diff now
Zound
My father had this problem with his e60 525i. Just before pulling the plug and purchasing a new diff, he removed the diff from the car and found that the main nut on the propshaft side was completely loose. It's like a 36 socket or something. The humming noise was most present on over run. Ie: coasting down hills in gear etc.
deanbenn
Have your rear wheelbearings checked before you do anything else. Had the same problem on both my Fathers 330d and my ex 330d. Everyone we took it to diagnosed diff on my fathers 330D and when it was eventually replaced it turned out to be the wheelbearings. On my ex 330d we suspected the same and I had the bearings changed. Noise was gone.
momo1
+1
Same issue on my old 1 series, had brand new WANLI V Tread tyres on the rear when I bought it, was sure it was the diff but change tyres first and noise dissapeard
Weskus330d
Got the same problem, as you call it playing with the pedals. would like to use your GUY but I'm down in Cape Town:thumbdo::thumbdo:
330Tractor
Thanks for all the advise.
But I don't think it can be my tires because they got replaced last week. So it must be the diff, does anyone know of a place in the Western Cape? I want to get it sorted out ASAP.:ty:
335i MTX
Was the noise there before or after you fitted tyres?
330Tractor
Before and after.
homeboy
Hello, please give me your contact, i have the same issue.
