BlownMotorWorks
Hi all,
I need some help with my 2006 325i e90 N52.
A couple of weeks ago the car started having problems with misfires on cold starts. The vehicles idles fine when it is starts but as soon as the rpm is picked up above a certain point it begins to idle eratic.The car can drive although there is a loss in performance and increase in fuel consumption.After a switch off and restart the problem persist.It will only idle properly after its been switched off for a couple of minutes when it seems it built up some heat.
The fault codes shown refer to the crankcase sensor , inlet cam sensor , misfires on all cylinders. The crankcase sensor was replaced but the problem only returned after a day or so.I also replaced the battery because the battery low sign came on a couple of times. I have been told it could be the VANOS,cold start sensor, mass airflow sensor etc.
Kilos are still quite low at 87000 and BMW did all the services.
