E90 320 Manual suddenly not starting
BMW-Driver
Hi guys
Need some advice before tomorrow... if possible.
My car started fine as per usual, no slow crank or anything. Stopped after about 30kms at a shop and the car won't start. Everything goes and looks normal, but I hear only a few relay type of clicks and nothing.
Got a push and running start works.
Went straight to a battery and exhaust garage. Car woth running motor shows charge. Battery checks out fine.
Phoned auto electrician and he suggested strongly that it is the starter. Which I so happened to have had replaced about 3 years ago. He says that it can go in two to three years. Although the last time I did have slower crank and two stops later it was dead.
Any advice would be seriously appreciated.
BMW-Driver
akash said:
Always start with reading any codes on the car
Thank you for the reply.
How would I go about reading the codes?
Nothing abnormal flashed on the dashboard and I don't have any diagnostic system I can connect to the car.
BMW-Driver
Thank you.
At the moment the car is being looked at, but it will be great to be able to diagnose and get an idea of what is wrong.
