E84 x drive shock replacment
rockitpras
Morning all,
Need to replace the front shocks, saddles etc on my e84 2.3d xdrive.
Any recommendations?
Currently looking at OEM, BILSTEIN and Monroe.
Kyle
Bilstein B6 would be a good upgrade over stock and likely cheaper than OEM too. Koni STR.T is also a good option.
Riaad
Events Organiser
Sachs will be the OE replacement and can be sourced from incomex (if im not mistaken)..just make sure you check the correct Sachs part number, as the xdrive models use different shocks to the sdrive.
agree with the above that the B6 will be a nice upgrade
