E83 X3 coding
Solo Man
I want to code my "new" 2006 E83 X3 so that the doors would unlock as i switch off the car. Would also like to code it so that the flashers do not flash when locking or unlocking. Also would like to get the consumption displayed as l/100km. How do i do it?
getty150
1st I don't think its doable.
2nd possible
3rd doable but I don't think coding is necessary for this one.
When I was investigating coding the options were limited for the e83.
Sent from my SM-A115U using Tapatalk
Blue Shirt
You can code the car with a K+DCAN cable and NCS Expert software, commonly available through various sources.
Coding is limited to what options are available in the respective ecu's. No1 cannot be done, 2 and 3 are easily done.
If you ever get to Stellenbosch or Somerset West areas, I can help you.
Solo Man
Thanks Blue Shirt. I have Carly and Bimmercode but not sure if they will work. Bimmercode will not connect/recognize the car.
