m0lt3n said:I thought only the 318i changed motors with the facelift. mmm
Will just have to make sure
Legacy said:What year model? The 1999-2001 320i has the M52 engine in which is only good for one thing basically: Massive Turbo
The facelift 320i has the M54 engine which is allot better, more torquey and some decent power. Nothing wrong with one.
BrownFox said:Legacy said:What year model? The 1999-2001 320i has the M52 engine in which is only good for one thing basically: Massive Turbo
I Have a 2001 320I pre face lift and it has a M54 motor.
It was built in September 2001.
Legacy said:BrownFox said:Legacy said:What year model? The 1999-2001 320i has the M52 engine in which is only good for one thing basically: Massive Turbo
I never said the pre facelift only came with the M52. What I'm trying to get across is the M52 320i is good for turbo charging and not much else and the M54 320i is allot better all round.
moranor said:pro: 6 cyl sound :rollsmile:
con: uses the same fuel as the other 6 cyl but you dont get the power![]()
moranor said:m0lt3n said:I thought only the 318i changed motors with the facelift. mmm
nope
320i went from 2l to 2.2l (not sure what other changes were made)
323i changed into 325i with different management, intake and exhaust (both have the same engine otherwise)
328i was discontinued
330i was released but it is very different to the 328i
you do get Pre F/L 330i and 325i but they only have different bodys the engine is the same as the facelift as far as i know...
moranor said:are you sure because the all the other M52TUB had double vanos as far as i know the M52B found in the e36 were single...
so then the M52TUB20 found in the pre F/L 320i should also be double vanos
[email protected] said:moranor said:are you sure because the all the other M52TUB had double vanos as far as i know the M52B found in the e36 were single...
:sorry:
you are in fact correct.
raise:
