E46 M3 tyre sizes
BillyBob
One would expect your rear 275 to be a 30 profile... which would make your front a 35 profile to keep it in balance.
You can get away with 245/35's up front - and while I'm not a fan of P-Zero's personally, many other people rate them as being a good tyre.
245's up front will indeed help with turn-in and overall balance - but bear in mind, you have to be pushing pretty hard to feel the difference.
Rockstar786
Thanks BillyBob,
You are right I would've preferred 275 or 265 section/30 profile tyres to keep the circumference front vs rear closer and the the gearing is a few percent higher than ideal with the 35 profiles on but the slightly taller sidewall does give a little bit more compliance over the bumps (and got a good price)
Little bit restricted to tyres that are almost just rubber bands around the wheel due to the 19" rim diameter:(
