e46 M3 Spark Plugs - So Called Replaced by Stealer..
Spiro
So... with the amount of flat spots and dead spots I've been having, Oil changes, tended to help here and there, mainly when the car was warmed up, they all seemed to vanish, together with this, I cleaned the Throttles on the Car, and ICV, this making a very stable power difference and/in delivery,
with this pickle... and the car's last Major Service was done at a Stealer... I would like to mention the name as those fuker's still owe me a new Key for my Car, 2 Years going now...
I made an attempt last night at doing an oil change, oil filter and The SPARK PLUGS... here is what I found...
I've attached the images, of the OLD Plugs and 1 New Plug, I've changed all of them, and wow... a very very very different car again...
Taking out the old Plugs after removing the first 1 had to be done with caution, as if you see the condition they are in... that explains it all...
Here are the Pics...
So basically.. the condition of these plugs shows that during all the major services the car went through... the plugs where never changed...
Sad case, but at least my car is running much better now...
Spiro
zama said:
It sux knowing that you cant trust anyone with your car anymore :argh:
I think the point of stamping a "Service Book" is now a pointless exercise and means nothing...
Peejay
Events Organiser
You should always ask for you old parts back. That way you'd know id they changed it or not. :thumbs:
Legacy
Actually under MP it does not work like that, they replace the old parts and then keep them for all sorts of reasons.
M3_FTW
Yep, while under MP you will not get the used parts back.
Andy1GP
They look quite worn. 155000km might be a stretch but not impossible. My Z4M went for an Inspection and they didn't do the plugs, took it back with some other niggles and they changed the plugs. They have it on the CIA and also mailed me the actual job card. It's about the best you can do with BMW. Unless you physically check.
