Andy1GP said:Pros
Car sounds fantastic. If you love the rasp you get around 4000rpm imagine that starting from 2000rpm and being around 2-3 times louder.
Car seems to have a little more low down torque.
Cons
You need to fit cat foolers (tiny cats that screw onto the O2 sensors)
If not, then the car will run richer than normal. Heavier on fuel, but won't go into limp mode. It does through a code on diagnostics but it's pretty much ops normal.
nasser@Joe said:when i had my E46 M a couple of years ago i decatted mine
here is a thread with pics and a vid
http://www.bmwfanatics.co.za/showthread.php?tid=25035
Andy1GP said:LoL
Only the US spec had cats in the headers. Our euro headers don't have cats in them.
So to answer their question it's the only cats that the car has that need to be removed, aka the secondary cats if you will.
Hi Guys, I need some advice, I removed the cats from my e46 m3 and now when I drive with my windows or sunroof open I am getting a exhaust kind of fuel smell, on top of this I no longer have the cats, please could someone advise what should I do, I spoke to power pipes and they said that cat foolers don't work on e46 m3. Does anybody have 2 x catalytic convertors for sale.Pros
Cons
As mentioned, this is a con of going catless on the 46 M3. There was a guy from Liatros on this forum who used to supply the foolers. The search should bring up his details .Hi Guys, I need some advice, I removed the cats from my e46 m3 and now when I drive with my windows or sunroof open I am getting a exhaust kind of fuel smell, on top of this I no longer have the cats, please could someone advise what should I do, I spoke to power pipes and they said that cat foolers don't work on e46 m3. Does anybody have 2 x catalytic convertors for sale.
Hi so you suggest i put foolers on the smell should go away,As mentioned, this is a con of going catless on the 46 M3. There was a guy from Liatros on this forum who used to supply the foolers. The search should bring up his details .
Hi no I haven't done anything so far, do you know who can do this for me,Have u disabled the following when removing the cats :
1. cat heating sequence?
2. SAP
3. cat enrichment procedure
If u didn’t do the above three your car will overfuel all the time especially on cold starts .
Don’t listen to the experts who say decat the car it will be fine.
Hi Yes i am in jhb, my number is 072-607-5713,If u in jhb send me a pm i will forward u details .
HiIf u in jhb send me a pm i will forward u details .
