Hi there,
I have a very similar problem to
http://www.bmwfanatics.co.za/showthread.php?tid=35449
I have a 2001 E46 330i F/L auto. :nonono:
Based in Gauteng
Also had a water loss issue and found it to be a hairline crack in the Radiator casing when under pressure. Never Overheated that I know of.
Had it replaced and all was perfect for the next month or two... Then on my way home one day after work, as I pulled into my driveway, I noticed the heat gauge start climbing. Pulled into garage, and turned off the engine. Noticed a water trail behind me as I pulled in. It leaks somewhere from the front. But I have Steam in the Exhaust now and the water system seems to be whitish and bubbles fersiously.
So, can it be a crack on the Exhaust manifold side leaking Gas into the Water System and therefore Steaming out the exhaust?
What do the honourable members of the forum suggest?
Take it in to a Reputable Place for a check?
If so Where? any Suggestions? I dont have big bucks in that manner that some I have spoken to suggest the repair will cost... 25 to 30k??
I have phoned around and can pick up a recon head for 3500 and a new one for about 8500. But maybe this is not the entire issue...
Any suggestions would be much appreciated.
Allen
Based in Gauteng
Allen
