E46 Emergency parts available
Luben
I've been meaning to list the parts that I've got available that can be used in an emergency just to get you home in case of failure. Some of the parts can be used in your investigations to eliminate a part as possibly faulty.
Most of the parts can be changed on the road side with minimal tools. I'll help if I'm available or else I can advise you.
E46 battery. Goes flat after a couple of days if parked off. I've got a battery charger so it can be charged up.
Top radiator hoses x 2
Bottom radiator hose
Lower radiator hose sensor, o' ring broken
Radiator cap
Water pump
Thermostat housing
Expansion tank x 3
Both idler pulleys on serpentine belt
H7 globes x 4
Air filter, used when I use to clean the BMC filter.
E46 reat calipers, not 330. Reconditioned with new seals, never used.
Gearlever.
The carbon fibre roundels have faded yellow so that's free for anyone to pick up(JHB Northern suburbs).
Sent from my GT-I9300 using Tapatalk
Luben
ChefDJ said:
Please add prices.
Some decent items there :thumbs:
I'm not selling them. I posted this up to help fellow fanatics in case of emergency. Most of them would be loaned out until the person sources a replacement.
///Moose said:
Are the 4 blue/white roundels OEM wheel caps? If so I'll take them
Sorry, I'm not giving those away. They are OEM and I'm keeping them as replacements in case of theft.
I took a picture of all the spare parts I had, sorry for the confusion.
Luben
ChefDJ said:
So these parts are here for lending?
And the roundals?
Yup, parts are for lending to the man in need.
The black and white roundels(3 for wheel and 1 bonnet) are give away. The OEM roundels are not on offer.
DieselFan
E46 battery does not go flat in a couple of days... You have a faulty battery then. My e46 was parked for 3 months used for a month and parked for 3 months repetitively in 2012 and always fired right up.
Kind gesture from you sir, well done.
Luben
I agree the battery is not perfect therefore I replaced it. If someone is stuck with a stuffed battery then this can do as a temporary measure.
