E46 compact window
rozzaxw1
Hey guys
not sure if this is broken or not but just to find out I'll ask you guys
on my e46 compact the window switches are 2 stage ie. One low pressure
pull and the window is manually moved up and down to where I set it
one higher pressure push or pull and the window goes down or up
fully all the way. Iam sure you get the drift.
This doesn't happen on the passenger side though it does the same
as the drivers side except it doesn't come up by itself when you give a higher
pressure pull.
I'm not sure if this is some kind of safety feature or if it's just not
fully functional or not.
Anyone else have this? I'm guessing most e46's have the same operating
process as the switches appear the same
let me know how yours works please
cheers
LAWLESS BMW
Hi
I have the same car as you, I asked a dealer about this, and they told me on the E46, the passenger window does not go up with one touch, only down. So you need to hold it till it goes up fully.
