E46 auto 'thud' noise from rear? 1st to 2nd.
herco
Hi gents!
I am planning on taking ownership of my dad's '05 320d. 255k on the clock and going strong.
However, when accelerating slowly the car makes a 'thud', almost grinding noise from the passenger rear when shifting from 1st to 2d. It never happens on downshifts, and under rarely under moderate acceleration.
Most often when slowly accelerating after a speedbump or cruising in a parking lot.
I doubt it's the transmission, as a lot of work was done on the tranny recently and all other shifts are silky smooth.
Guessing it's diff or prop related? I'm nervous a thud becomes a THUD.
Nikhil
1) Engine mounts
2) Rear diff bush
Both those items will be shot at that mileage if never replaced and both give you the above symptoms mentioned.
herco
Nikhil said:
1) Engine mounts
2) Rear diff bush
Thanks Nikhil and @"Camnefdt".
I think engine mounts is a good place to start, as the car feels abnormally shaky at idle.
I will have them both replaced at the same time.
Tinuva
Staff & Webmaster
Nikhil said:
1) Engine mounts
2) Rear diff bush
OP, this is the answer!
The rear diff bush is definitely gone. Probably needs replacement every 100k km.
The engine mounts, is what I also need to look at next.
herco
Tinuva said:
Nikhil said:
1) Engine mounts
2) Rear diff bush
Yeah, everything I get my hands on points to diff bushes.
Any idea at the cost involved to replace these?
Tinuva
Staff & Webmaster
herco said:
Tinuva said:
Nikhil said:
1) Engine mounts
2) Rear diff bush
This was a quote on Jan 2020.
Sent from my Mi 9T using Tapatalk
Tinuva
Staff & Webmaster
Did you go for the poly or the original from agents?
Poly. At this point, I am not sure if it will last longer than the oem.
They fail different. OEM rubber breaks apart. Poly becomes rock hard from what I understand, so it also needs to be replaced eventually.
Nikhil
I went with OEM eventually which has lasted the longest, did Meyle, teknorot and Febi and they all failed very quickly
Tinuva
Staff & Webmaster
How quickly if I may ask?
Currently on Powerflex purple (normal road driving version). They also do Powerflex black for racing which I decided is not what I want.
Nikhil
20k km approximately on the Meyle and teknorot, febi was about 40k km ish. OEM has been on for 80k km now no issues
Tinuva
Staff & Webmaster
Oh wow thank you. Expected a bit more from Meyle but I guess it is what it is.
The OEM I expect to last at least around 100k if not a bit more. I will see how long this powerflex last, but I do like the slightly softer feel of the OEM a bit more. Its actually worth it.
KPM3_30
Moderator
@"Tinuva" Meyle quality has gone to shit in recent years with them manufacturing parts out of China.. I know of so many cases where Meyle parts have failed soon after fitment.
I chose to rather buy parts from the agents where I could only find Meyle. If not Meyle HD, don't bother.
