E46 Angel rings (Who supplies?)
Kamz
Hi Guys,
Can anyone provide me help on where to get e46 angels rings in JHB?
I tried Autostyle and as usual they dont have stock.
I also tried MST , same story...
bimmer330
I had three sets allready.
first set from Autostyle, and two from Boksburg market.
ones from the 'market where better quality.
they allways have in stock.
you can get for R750.
make sure to check the kit properly when you buy from Autostyle.
the set I got from them's rings where not all the same size.
they gave me three different sizes in one kit......
ones from market was perfect, all 4 rings same size...
Kamz
Boksburg flea market isnt that far from me:) Think i will take a drive there on Sat. Thanks for the advice i will look out for that. Do those angel rings break or burn out that fast? and the one from the flea market is it made esp for the E46?
Kamz
From what i know you remove your headlight cover(On an e46 it just unclips) and the rings just clip onto the light. Quiet simple i assume...
mrv said:
hi guys
how do you fit these into the headlight?
osiris
clip in angel eyes? this is interesting....I spent many hours placing my angel eyes in my E36 and gluing them in properly and doing the wiring etc etc, it was no easy task I can confim that!
kabal
e46 and e36 use the same set. normally the rings come with a "clip" that connects to the reflector, however the e36 does not have the reflector the same way, so you end up removing the clip and using double sided tape, which worked best for me.
was 100x easier installing them in my e46 headlights
osiris
yea I saw this clip that you speak of but it didnt clip in anywhere unfortunately :( didnt come with double sided take either, lol I guess I just have bad luck.
Epoc
Here is a link that I found with decent pictures on how to install:
E46
http://forums.bimmerforums.com/forum/showthread.php?t=1278619&goto=nextnewest
E36
http://forums.bimmerforums.com/forum/showthread.php?p=10571551#post10571551
Hope this helps.
mrv said:
hi guys
Bimmer330 ...
Do you have any pictures? Are they bright enough? 7000K?
Do you have the name of your set.
nawtiboy
anyone done the install on facelift coupe ?
not so keen on heating them headlights :mmm:
would be nice if someone here in jhb can do the fitment for glued units:thumbsup:
rodga
+1
@nawti - a bit off topic, do u no wat the clear/white lenses cost? do u have to replace the entire headlight or can u get some sort of insert and just replace the amber lense part?
nawtiboy
+1
been trying -cause i also want to change the amber corners -otherwise just put the angel eyes and leave it orange -or maybe a slight smoke ?
rodga
those ambers suck big time, everytime i look at it i throw up a little in my mouth
(talkin bout mine, not yours, yours is the sh*t!!!:))
Oh_Yulz
Its working out cheaper to buy the angel eye rings on ebay with postage than most of these accessory stores. I just ordered a set. Worked out to R383. Autostyle is R495 and Max Motorsport is R595.
osiris
Anything amber should be banned from cars it looks rediculous and so does a fat number plate over the air intake of your nice E36 M3 bumper. cops always catch you with your back number plate anyway so I dont see why we need a front number plate but anyway.
ok venting over :p
My angel eyes came to frikken R700 from Autostyling :( just make sure your angel eyes that you ordered are not just the cathode tubes, make sure they have a plastic casing else they look kinda lame and will break very easily.
Rapido WP
The ones I got came in a plain brown box, which are much brighter than the ones in the full-colour blue box. They do take time to install - make sure you use Pratleys glue, I would not trust double tape in the heat of summer. I've had to replace one of my transformers already, but that could have been caused by the hosepipe. All 4 are the same size and have the plastic casing. Silicone your transformers into the underside of the black rail above the lites. But dont drive around with them on in the daytime - you can see f..all!
E46
E36
The American did a crazy connection, using a remote switch - just connect them to your park bulb wires (& use the bulb hole to run your wires thru - that's the hardest part.
