Bandile
Ralf@Speedway Motorsport said:it all depends on the configuration of your exhaust system
1) If you have CATS that are co-located on the manifold with sensors integral to the CATS, then you can either a) remove the manifold, then "hollow out" the CAT, ie remove the internal platinum stuff, and then replace it, it will still look exactly the same.....I think we would charge about R600 per CAT to hollow out the internal stuff, mainly a labour job with new manifold gaskets and some welding....or you could change the entire manifold for a set of branches from VIPER or utilize a set of E36 328i headers, as these have fittings for the sensors..........in both cases no re-mapping is necessary
2) If you have CATS situated under the car, about mid distance, then these are generally not fitted with any sensors, so a straight forward cut and replace with a straight piece of exhaust pipe....about R150 per CAT/Pipe or you could substitute the CATS with a freeflow box, for another R350-R400 or so
In all cases the sound will not change by very much, as most of your cars "REAL" sound changes and silencing is derived by the rear box
Ralf, you have PM sir.
