Hi Mr Smooth
i have been meaning to pop by some time to have a chat, but i thought why not discuss it here so it can maybe help other members...
i have an e46 323i which is being built as a drift car...
i will soon be chipping it will you :rollsmile:
so far i have done a 6 speed conversion with a 3.38 diff a mandrel bent duel 57mm free flow with viper branches i am working on a custom short ram CAI...
im wondering what rpm i should put the limiter at when i get it tuned... with some help from a forum member (Raybimmer) based on a calculation using piston speed i should in theory be able to run up to 7619 rpm...
but i have no idea if the hydraulic lifters, con rod and bearings will take 7500 rpm...
most tuners seem comfortable taking it to 7000 rpm... so my thinking was if the a 328i can run at 7000 rpm safely and my car has the same bore, but it has a shorter stroke it should be able to rev a little higher...
please advise me :rollsmile:
