E46 318i Reving on its own
chase-GP
Hi Gents.
My 2004 E46 318i recently just started reving on it own.
The car was parked for about 2 months with regular starts now and then.
But the battery ran flat and I jumped started the car and then it started reving itself...
Any clue what this could be?
Is there a DIY solution?
Please help :hammerhead:
danieljames
As in rev hop at idle? (I.e. it's bouncing up and down and not settling on 900 rpm. )
Or is it sitting up at the red line and bouncing off the rev limiter. ?
Sent from my HUAWEI GRA-L09 using Tapatalk
chase-GP
Yes it's hopping revs up and down to about 2000 rpm
danieljames
Check that all your vacuum lines are tightly secure. Also check for cracks on all the lines. I'm no expert but with the e36 this is a common issue
kilotango
that jump start could've messed with stuff..
i reckon try and disconnect your battery completely, then touch the positive and negative cables from the car (not the battery) together to flatten any voltage that may be present in the system. it will "reset" everything.
hook up the battery again.
also have your battery recharged fully or tested incase its become faulty
Ashiel
I had the same issue, i cleaned out the MAF Sensor and it was sorted
It was also after the battery went flat and i jump started it
Donovan2412
chase-GP said:
Hi Gents.
How long did you let it idle for?
Lizzard
A bit late, hope this is sorted by now.
If not then maybe unplug the MAF or the ICV (idler control valve) and see if the car stops reving. Had this issue on my E36 where it will just start reving while I am at the stop, everyone thought I was a learner :biglol: . turned out to be a dirty ICV that I just cleaned with some tissue and alcohol.
Lizzard
Jip and then when you go the car will bulk and you would look like you need a L in the rear window :biglol::biglol:
chase-GP
Thanks will give that a try otherwise it could be the MAF
Thanks but how did you clean b the MAF I am worried it gets damaged whilst truing to clean it????
NFCKN said:
So when you at a traffic light the car next to you thinks you want to go for it...:rollsmile:
LOL:biglol:
Thanks will try all possible solutions
And will update everyone once problem has been found
