E46 318i N42 non starter
samman325
hi guys,
need some assistance please with a 2003 E46 318i. Car refuses to start. Got all ignition lights, cranks, but doesn't pick up.
Upon close inspection, realised fuel pump is not priming when ignition is switched on. Checked power to the pump... fine. Checked the fuel pump fuse and relay... fine as well. Checked continuity at the pump plug... also fine!
This would suggest the pump has failed... BUT... when plugging in a new pump... still NOTHING!!! All fault codes relate to fueling issue and crank position sensor but once cleared, did not reappear.
Any assistance will help please!
