Iceman007
Im glad I dont have a e46 318i Face lict 2002 and its my Dads. That N42 engine just loves its oil leaks. First the Cam sensors leak replace the O rings fixed. 6 months later the Vacuum pump leaks oil replace O rings, 3 months later Agents replace Vacuum pipes/ Oil seperator and they dont replace the dipstic O' ring :thumbdo: and yes now its leaking so I replace it. I look up and now I see the plastic Cover plate on the head is leaking water so ill have to replace that. At this rate Ill be rebuilding the Engine Bit by Bit
