E36 Stabilizer bushes/mountings - do eet!!
Peejay
Events Organiser
moranor@axis said:
lol sold bushings will do that yes :)
powerflex also offer the Black series now for people who want harder polly for track use
Do they offer those for M3?
Coupe Turbo GP said:
So... What do we replace with poly and what do we replace with oem for the best of both worlds, comfort and performance :fencelook:
I would say everything polly but rubber subframe mounts is you worried about noise...
even then i find it hard to say the subframe mounts are letting in more noise but i would rather be over cautious with my advise than have someone unhappy...
you can get any powerflex bushes in the black series but i dont advise it for a street car... normal powerflex range work very well on the street
sclass
Heven said:
So poly is better then oem?
From a proven brand like Power Flex yes they are. And the argument about harsher ride etc to me doesn't really hold because any new bush, OEM or otherwise, will feel tauter than old knackered ones you've just swapped out!! The comparison should be between new OEMs and new polys on the same vehicle but how many owners have actually conducted such a back- to-back test...?? Besides the runflat guys have more to be worried about than the poly guys :) :fencelook:
Nikhil said:
Yes Polly is much better than oem as well as stiffer. I fitted the turner motorsport race bushings which are aluminium, and the car feels like a bakkie with leaf springs every time I go over a bump Lol:fencelook:. I would not suggest it if your car is a daily drive! Polly is the compromise between performance and comfort. :thumbs:
That must make for an interesting ride :rollsmile:
Nikhil
Lol its pretty entertaining! However my passengers don’t appreciate it much. :fencelook:
Doomsdaya
I'm gona start saving up from now...
Sean, +/- how much would it cost to buy all the bushes for an e36 sedan ?
Fuzz@tinyNET
I am probably going to have to do the same on my car :fencelook:
Getting that clunking noise and tail-happy action too :fencelook:
Meyle rubber bushes for e36 6cyl (widely regarded as the best rubber bushes you get)
Front suspension:
LCAB 136 531/136 532 – R 820 a pair
Complete control arms with balljoints pre-installed R 2380 a pair
Tie rods 139 313/139 314- R 720 a pair
swaybar bushes cant get Meyle see powerflex^
swaybar end links cant get Meyle
Shock mountings R 1010 a pair
Front drop/stabilizer links R 580 a pair
Rear suspension:
Shock mountings R 300 a pair
subframe bushes front cant get Meyle see powerflex^
subframe bushes rear cant get Meyle see powerflex^
bush #2 cant get Meyle
bush #3 R 450 a pair
bush #4(RTAB) R 330 a pair
bush #6 R 360 a pair
bush #8 R 300 a pair
for the bushes i cant get in the Meyle range BMW is probably your best bet as they are not often replaced most bushes will be shared with the M3 :) M3 specific bushes will have to be got at BMW also...
Front suspension:
Rear suspension:
