E36 M3 brake pedal fading..
KPAKKIRI
Hi guys,
I've noticed that that brake pedal of my E36 M3 is fading. If you pump the brakes then she holds much better. The is no loss of brake fluid. I suspect it's the master cyclinder. Is this a big job for the experts or can I attempt it? I do know some mechanics.
Regards
KPAKKIRI
hermanbriel said:
Maybe start with bleeding the brakes first.
Done that. I held good for a week and then started to fade.
Just contacted BMW now and they don't offer a kit. You have to buy the entire cyclinder at R8500.00.
Peejay
Events Organiser
Fluid change yes. Check to see if the brake fluid has gone black. If so time to change. Use BMW brake fluid also
KPAKKIRI
Done that as well. Bled the entire system with new fluid.
