E36 M3 4 Door Owners
tyu333
Hi Guys
Have any of you replaced your Lower Control Arms? If you have replaced them with after-market where did you did you source the parts and what was the cost?
Raybimmer
Meyle HD from Goldwagen for e36 are not bad ,I think the arms are the same the difference is the rear mounting ( lollipop ) it has an offset bush .
the lollipop bush is different to add more caster :)
I have powerflex bushes for the M3 they go for R 750 a pair and have lifetime warranty...
resize_image.php
Peejay
Events Organiser
resize_image.php
What's the flex is these same as OEM or stiffer? And do you keep the diff bushes?
powerflex dont make diff bushes for the e36 yet...
they should be a little firmer than stock, but that said i have the e46 ones on my car and they feel smooth to me...
Raybimmer
Thats why e36 upgrade is to fit M3 bushes :thumbs:. When the steering is turned full lock the wheel leans over a bit more .
What about Teknorot brand ?
tyu333
I was a bit sceptical about the regular e36 control arms as Realoem lists different part numbers for them.
So would I be correct to buy regular e36 control arms and fit M3 specific bushes.
So would regular e36 front stabilizer bar links work on the ///M?
Regarding Teknorot, I read somewhere on the forum that there's guys using Teknorot parts in their race cars without problems. Where does one find Teknorot parts in JHB?
Raybimmer
I was told the only difference between the control arms is the bush - any body know if they are the same ?
Gizmo
Banned
As far as the lollipop bushes go, 3.0lt M3 has the off-set bush. 3.2lt M3 has the centre bush, both are solid unlike the std e36 ones.:thumbs:
