Hi Guys,
My car had a very annoying intermittent misfire, especially once the car has reached operating temperature, and this happened even more often if the ambient temperatures were quite high as well. Typically it would feel like all spark/fuel was cut to the cylinders and then it would feel like it was running on 5 cylinders or even in limp mode. Diagnostics picked up no errors and no one could tell me w.t.f. was going on - so I did the following:
Replaced all 6 coil packs and suppressors - problem still persists
Replace CVV and all vacuum pipes - problem still there
Replace fuel pressure regulator - same nonsense
Test fuel injectors , compression etc. - no fault found
Replace coil pack harness - still
Took it back to indy - and eventually it was found this was caused by the vibration damper (crank pulley) that had failed ! Due to age the rubber damper has fatigued which causes the crank sensor to every now and again "lose" the pickup and in turn generate a misfire error to the ECU. So BEFORE you go and spend a LOT of money on other parts like I did - check this part out first
I really do hope this will help someone else with the same issue and save them money in the process - my car has about 400 000 km's on the clock so I guess it was due :rollsmile:
