E36 318i Oil Q
W
wikk3d88
Having a bit of a brainfart day today... What is the correct spec Oil for my 318i (M42)?
Recommendations for a decent brand? I see Mobil1 being mentioned quite often.
Oh, my mileage is 110 250km, so does it make a difference if i use semi-synth or fully synth oil?
M
Mike1
Any modern day oil will do, stick with a 5W40 and get something with a BMW Approval on the can and an API rating higher than an SG.
I dont recommend Fully Synthetic as in your motor there will be virtually no benefit over a standard hydro-cracked oil.
Oil Thread Fight in 3..2..1...
andrewbuch
:rollsmile::rollsmile::rollsmile:
:thumbs::thumbs:
5W40
M
Mike1
Which will say exactly what I said above - If he wants Liqui Moly then Top Tec 4100 is the one.
W
wikk3d88
Mechie who serviced it last said he used SHell Helix 15W40 :fencelook:
W
wikk3d88
moranor@axis said:
that has very bad start up protection :yuck: you want a 5w40 or a 0w40
Yeah, Ill go with a 5w40 on the next oil change. Hopefully won't cause any issues further down the line
