E36 318i issues after battery replacement
nazzeem
This happened before
My battery ran completely flat and after fitting an new battery the windows & central locking does not work. The front windows was not closed properly and stayed this way for days. After much struggling another try with locking the driver door and turning the key that extra bit to the left which normally locked doors, rolled up windows and activates the immobilizer thing sorted the problem. After the windows closed everything worked fine.
That was a loaned battery. I replaced the loaner and now have the same problem.
Car starts fine, but air-con gas is empty so driving with closed windows is not nice. I have been googling much for this issue last time and now again. Mentioned was re-sync which I`m not sure how it is done. Also I have tried the window reset method where the car is supposed to be on, but not started and then holding down the windows close button for 15 seconds.
Nothing is working. When unlocking all doors manually and locking driver side door, only the driver side door closes. I am going to check fuses 11, 14 and 43 as described here soon bmwe36blog
Any advise will be appreciated.
nazzeem
Loom said:
Thanks for the follow up comment. Do you know what unit caused the problems?
No not sure. It was about 200mm long and 50mm wide. Apparently it controls the electric windows, central locking etc.
New problem here
