e34 540i lower control arm bushes
J
Jandre
So, it seems my lower control arm bushes are shot.
Any recommendations from you guys? maybe poly bushes?
Anyone with a contact for some maybe?
P1000
Get Meyle parts and make sure you get the /HD version, which lasts twice as long as oem. Go to meyleusa.com and look in the bmw section for the part number, then call Incommex for pricing.
zaleonardz
If i can pipe in here as well, avoid the cheap crap. I figured I can put in the cheapies so that they last for like a year, and then do a full bush replacement all round when I have some $$$... sounds logical right... wrong....
Not too sure what died yet, but probably going to have to replace the whole lot.
I recall somebody saying for about 4k you can get the entire front suspension from Bemow's, all new... so guess thats my next move.
rick540
The guys use the 750i bushes which are real HD.
Poly bushes will break your teeth, good for a racetrack only. The BMW front suspension designs actually rely on the compliance of the rubber bushings to give both feel and handling for a street setup.
bmw111
i found out that goldwagen also sells the whole lower control arm they have the steel one and the alluminium ones. i asked them about the quality and they said that it is also imported and is more or less the same brand as imcomex has anyone tried the goldwagen brand?
P1000
I looked at those, they are TOPRAN, I would not take the risk as they are much cheaper, and my time is worth a lot to me, so I did not want to do it twice. I chose to rather go the tried + tested route with the meyle ones, which are recommended on international forums and suppliers.
Die_Miek
how is the ride quality of poly bushes?? is it much harder than oem bushes?
i read on the forum of poly bushes for around R120 each somewhere in parow.
Polyparts im very happy with mine :) they were a rock hard when i 1st put them on but seem to have softened nicely now i get good steering feel and they not too hard
Die_Miek
how long ago did you put them on?
Redline
How long in km's did it take for them to soften. I too need to replace some suspension parts. I'm not against a firmer ride as long as it's not spine breaking & still offer good feel.
Redline
@ Rick540i Forgive the ignorance but what is HD:thinking: (besides 1080p :))
