Hi guys,
I'm battling with my 730 and would appreciate some input to sort her out.
A bit of history first: the car stood for a few years due to a blown head gasket, top was redone, the company doing it went belly up shortly after I handed the head in and it took some time to get it back.
Last year we started to rebuild her and all was right again for a while after replacing fuel tank, fuel pump and obviously the filter too.
After a 500km trip last weekend, she has developed a miss/rough running under load.
As long as I keep a light right foot she pulls fine and runs smoothly but if I try to accelerate harder, it's like she runs into a wall and I can feel a roughness.
I've noticed that as long as I keep the economy meter (which responds to vacuum as far as I know? ) under about 20l/100 she's smooth but if I go beyond that she misses.
I've replaced the 2 vacuum lines from the intake manifold to the fuel regulator and side of the MAF/throttle body coupling because they were very old and dodgy. I thought it might be a vacuum leak somewhere but it made no difference at all.
What's interesting to me is that under steady throttle conditions the needle in the economy meter seems to move all the time - on our E39 it tends to be very stable under the same conditions.
Where do I look next - fuel regulator, injectors, timing? Somewhere else?
