zippy320
Hi Guys
So I have a little time to do some work on the E30 , Decided to look into the brake pad wear sensors and my indicator issue .
The sensor light on the dash is constantly on , I checked and replaced the sensors , checked the wiring and everything seems fine .
I took the sensors off , Bridged both wires which should turn of the light but the light wont turn off , I took out the speedometer , checked the internals ( I read that a loose solder could cause the issue ) and I found no issue there .
I am now stumped .
My indicator , When I turn on the left indicator , I can hear the ticking , I can see the indicators working outside , but the green light on the dash wont flash .
While the speedometer was out , I replaced the bulb with a new bulb , I also swapped it out with the right side bulb and still no flashing on the speedometer .
Not sure where to even start with that . Could a relay or fuse be burnt? Seems the speedometer does not know the cars flashing?
Anyone have any ideas for me on these two issues?
Where does the Brake pad wear sensor plug into at the back of the Speedometer? I thought worst comes to worst , I could rewire the thing as the original wires seem to go into the cars complete harness .
Thanks guys for all the help! This car wouldn't be where it is if it wasn't for you guys!!
I am now stumped .
