E30 clutch and pressure plate
Howzat
How hard is it to do this? One man or two man job? My clutch is taking high up and after some searching it says my clutch need replacing.
Dankie
Sent from my GT-I9300 using Tapatalk 2
will tell you when i do it... im going to be tackling this job in the next month or so...
general consensus is this is a job not worth doing DIY but I want to be able to do EVERYTHING on my car so i will give it a go at least one :rollsmile:
hennie
if you are strong as an ox its a one man job
but you will need an assistant or 2 if you do it farm style
this is on the ground on your back
