dvd player VS climate controls
rocketracer
The Mac said:
Hi Guys,
this is what I'd like to buy and install into my 2001 330ci
http://www.stopshop.co.za/1967-buy-...pod-bluetooth-7-touchscreen-ssas-bmw010-.html
To do so I would have to remove my climate controls as my dash looks like this:
http://www.realcode.com/Docs/CarPC/dash-before1.jpg
In the specs for the DVD it says "can-bus + aircon agreement", does that mean I can control the fan, aircon, heater via the dvd player ?
Many thanks for your help
Mac.
your climate control moves lower down to where the storage compartment is.
here's a complete "how to". http://forum.e46fanatics.com/showthread.php?t=390158
hope that helps :thumbsup:
The Mac
hi thanks a lot for that.
I think my climate controls my be too long to fit there. anyone know if the climate control unit size changed from 2001 to 2002 models?
The Mac
hi,,
that was just a pic i found off the net to show the type of interior I have.
thanks for heads up on stopshop. Almost walked into that blindly!
I'm just unsure about the length of the climate unit and the sunglasses compartment being the same. I guess I'll have to measure it and get back to you guys.
thank you for being so cool. I'm a first time BMW owner and I've already been through, in the first month :
1. overheating due to water leak ( new thermo, waterpump, hoses, pressure tested radiator and expansion tank) (+/- R3000)
2. Broken disa flap (R2800)
3. Service (R2000)
next month : brakes.
Sankekur
You get a relocation bracket for the A/C controls (from BMW), the controls then go where the sunglass holder would normally be.
marc
That is a hot unit. Looks like a good mod and still has that OEM look to it. Must start saving:bawling:
The Mac
I'm gonna phone bmw supertech and ask them for the bracket. Anyone know a part number or what its actually called?
I'll do the mod myself. while I'm at it does anyone know where I can get silver/chrome replacement for the wood finish on the dash and doors?
Thanks so much! I will take photos of every step and put it up on here.
KING_RSA
Looking forward to you progess reports & Pics Mac :thumbsup:
I am buying one this morning and Gizmo is gonna be installing it for me :excited::excited:
The Mac
King,
Can you ask gizmo what else is needed , Imean besides the dvd player and the bracket.
Also will there be any cutting and trimming or is it just "unscrew ,remove, relocate, screw, watch dvd"?
heres a guide : he is a bit unclear about the bracket though :
http://webcache.googleusercontent.c...1&hl=en&ct=clnk&gl=za&source=www.google.co.za
KING_RSA
King,
Im not sure, as I dont have any technical knowledge. Therefore im gonna get him to do it for me. You cam PM him for information
Sankekur
If it is a good nav system it should fit right in, no timming needed. I haven't done this before but the steps should be something like this:
-remove the trim on the passanger side
-then remove the trim around the radio, in both cases pry it loose with a butter knife wrapped in a cloth of some sort
-unscrew the radio pull it out and disconnect
-remove the sunglass holder by opening it and then pulling it outwards on the lid, it just clips in place
-remove the shift lever boot by pulling it inwards (towards the shift lever) and upwards at the base of the boot
-loosen the trim that surround the gear lever by removing the two screws (at the back)
-now remove the AC control panel, if I am not mistaken it also just clips in place.
-you should now be able to unscrew the whole bracket, unplug the buttons and remove it
after this it is just a case of putting in the new bracket and replacing everthing
Also note that there are two types of relocation brackets, the on take a single module containing all the buttons (DSC etc) and the other takes individual buttons, so just be sure to get the right one for your car.
