Door Mirror Refurbishment - DIY
Hugo_za
Ok so the previous owner of my 7er's wife completely trashed the driver side door mirror the day I took delivery of the car.
The inner magnesium frame was broken and as such there was no reliable way to affix the mirror to the base. The cost of a new one with all the parts would be over R10k and the breakers don't have any either. I tried q-bond at first, which worked, but it was just too easy to knock the mirror off again. I took the whole thing off, and started looking for a way to permanently affix the mirror to the frame. This was my solution.
I cut a slit through the metal base and used a metal clamp, looped through the mirror frame and base and tightened it. Solid as a rock now.
I then sanded down all the parts going to progressively finer grits. The mirror cap was badly damaged and cracked so I used epoxy putty to fill it and sand it down. It was my first time working with a filler and the results are awesome. Sprayed it all flat black and fitted back to the car.
And lastly a before and after photo.
Took a couple hours of my time and around R200 for all the materials.
Hugo_za
Yup, thats next weekends project. Will see how the refurbished mirror holds up with a week of daily use.
I am also thinking of spraying the chrome around the windows with the same flag black. What do y'all think?
ChefDJ
It's a 7. Keep the chrome.
Well done on the DIY :clapper:
ChefDJ
Hugo_za said:
BMW did offer the E65 with the shadow line trim after all...
I would try gloss black instead of matt, though :fencelook:
I must say, Hugo, that you have the balls to attempt stuff on your 7 that most wouldn't even try on a less stately model. Like fixing this mirror like that.
Mucho respect :thumbs:
Hugo_za
Thanks Chef! I'm adventurous like that. Being a little technically minded doesn't hurt either. But most of all I love being able to do things like this myself and in the process helping others. Sure I could go and buy a new mirror but the cost is absurd, especially when such a cheap fix is possible.
Hugo_za
ChefDJ said:
So now how's about you build me a 7 from scratch for mahala? :rollsmile:
Sure thing. Bring me the parts and I'm confident I can assemble it for you...mahala :p
Hugo_za
Just an update after a week with the refurbished mirror installed.
Nothing to report. The end.
Lol, anyway. With all the rain and what not I was very happy to see that the paint job is holding up perfectly. No rain sports or anything. If I look at both mirrors while driving the refurbished one looks totally OEM. The color is even the same as the black frame around the passenger side one. I will sand done the passenger side mirror and paint it this weekend to maintain balance ;-)
Nastaliq
Just check what paint you are using, as the rattle can type isnt UV stabilised and will start to fade over time.
If you take both off, sand and prep, I am sure a panel shop will be happy to undercoat and top coat for you with proper automotive paint, which will provide more longevity for sure.
Hugo_za
I used Rustoleum flat black paint and primer. UV resistant and highly rated for outdoor application. Push comes to shove I can replace the mirror frames and caps on their own now that the base has been repaired.
I am not expecting it to last forever, though I have read on several forums that the product lasts well over 5 years.
Nastaliq
5 years is very decent ROI time, for R200.
Good job.
